I produce a HDL functional model from a schematic file, and it shows "BLACK_BOX"!!!
The schematic file is attached below. All the components(AND3B2, AND3B1, AND3) are chosen from the libraries which were automatically installed. After composing the schematic file, I produce the HDL functional model, but it shows “attribute BOX_TYPE of AND3B2 : component is "BLACK_BOX";”. “attribute BOX_TYPE of AND3B1 : component is "BLACK_BOX";” “attribute BOX_TYPE of AND3 : component is "BLACK_BOX";” library ieee; use ieee.std_logic_1164.ALL; use ieee.numeric_std.ALL; library UNISIM; use UNISIM.Vcomponents.ALL; entity ymq2 is port ( A : in std_logic_vector (1 downto 0); en : in std_logic; Q : out std_logic_vector (3 downto 0)); end ymq2; architecture BEHAVIORAL of ymq2 is attribute BOX_TYPE : string ; component AND3B2 port ( I0 : in std_logic; I1 : in std_logic; I2 : in std_logic; O : out std_logic); end component; attribute BOX_TYPE of AND3B2 : component is "BLACK_BOX";
check this ARS
http://www.xilinx.com/support/answers/9838.html
Thanks and Regards
Balkrishan
what is the issue it should be fine . Are you not getting expected results .
No attachment with post!
Thanks and Regards
Balkrishan
Schematic picture is here!
Sorry, I cannot post the attachments.........I don't know what is wrong.......I'm wondering why are the components are "black". Should I write the behaviral architecture for the components?
check this ARS
Thanks and Regards
Balkrishan
Thx for your answer! A black box is any instantiated component that is not represented by HDL code, but rather by another netlist format. So in my case, the components are not created by HDL code. I just don't need to care about it!
