I produced a HDL functional model from a schematic file, and it shows "BLACK_BOX"
The schematic file is attached below. All the components(AND3B2, AND3B1, AND3) are chosen from the libraries which were automatically installed. After composing the schematic file, I produce the HDL functional model, but it shows “attribute BOX_TYPE of AND3B2 : component is "BLACK_BOX";”. “attribute BOX_TYPE of AND3B1 : component is "BLACK_BOX";” “attribute BOX_TYPE of AND3 : component is "BLACK_BOX";”
library ieee;
use ieee.std_logic_1164.ALL;
use ieee.numeric_std.ALL;
library UNISIM;
use UNISIM.Vcomponents.ALL;
entity ymq2 is
   port ( A  : in    std_logic_vector (1 downto 0);
          en : in    std_logic;
          Q  : out   std_logic_vector (3 downto 0));
end ymq2;
architecture BEHAVIORAL of ymq2 is
   attribute BOX_TYPE   : string ;
   component AND3B2
      port ( I0 : in    std_logic;
             I1 : in    std_logic;
             I2 : in    std_logic;
             O  : out   std_logic);
   end component;
   component AND3
             I1 : in    std_logic;
             I2 : in    std_logic;
             O  : out   std_logic);
   end component;
   component AND3B1
             I1 : in    std_logic;
             I2 : in    std_logic;
             O  : out   std_logic);
   end component;
begin
   XLXI_1 : AND3B2
      port map (I0=>A(0),
                I1=>A(1),
                I2=>en,
                O=>Q(0));
   XLXI_2 : AND3
      port map (I0=>A(0),
                I1=>A(1),
                I2=>en,
                O=>Q(3));
   XLXI_5 : AND3B1
      port map (I0=>A(0),
                I1=>A(1),
                I2=>en,
                O=>Q(1));
   XLXI_6 : AND3B1
      port map (I0=>A(0),
                I1=>A(1),
                I2=>en,
                O=>Q(2));
end BEHAVIORAL;
Ok, so you want schematics of gates. good luck.
So your question , why black box's
If I remember, and it is going back 20 odd years,
     gates are macros / known code to the synthesiser,
          so when the synthesiser sees these , it does not need to do any work, it can 'just' drop them in.
thesimulator as well needs to know what these box's are,
    but if your using th Xilinx simulator , then its built in,
I love using schematics, BUT for top level blocks,
     coding using gates is goign to get REAL big and messy real quick.
Only one question
WHY schematic ?
I think the schematic design is more convenient to create the top module than the HDL codes.
@malarkey1989 : Please avoid posting multiple topics with same issue and content. The duplicate one is
https://forums.xilinx.com/t5/Simulation-and-Verification/I-produce-a-HDL-functional-model-from-a-schematic-file-and-it/td-p/656328
Debraj
Thank you sincerely!!!
I'm really sorry. At first, I post one topic, but I don't know where I can find it. So I had to post it again. Please tell me where I can find all the topics I have posted. Thank you very much!
