hpoetzl
Voyager
Voyager
ICAPE2 and FRAME_ECCE2 Simulation
I'm currently investigating the ICAPE2 and FRAME_ECCE2 for 7 Series dynamic reconfiguration, error detection and correction.
I've written a simple example which writes a frame with a single bit error and then reads back the frame data to trigger the FRAME_ECCE2 error detection.
This seems to work well on real hardware (Cmod A7 35T) and produces the expected output, but when I try to simulate it, I get a warning that a frame data file is required for FRAME_ECCE2 and that I should use X_ICAPE2 to generate it. The simulation continues but produces empty output for ICAPE2 and FRAME_ECCE2.
I didn't find anything about X_ICAPE2 in the documentation so I'm not sure what I'm supposed to do to make it work.
Any input would be appreciated.
Thanks in advance,
Herbert
-------------- Yes, I do this for fun!
austin
h,
Simulation of such complex behavior is not done.  As you discover, the part works exactly as described.  The simulation, not.
Austin Lesea
Principal Engineer
Xilinx San Jose
hpoetzl
Voyager
Voyager
So what is the X_ICAPE2 mentioned here?
