05-08-2019 08:44 PM
Hi~ I want to transplant xlinx floating point IP core to IES. I have added *_sim_netlist.v in the IES simulation. But I meet the errors below.
ncelab: *E,CUVMUR: instance '{*Name Protected*}' of design unit '{*Name Protected*}' is unresolved in '{*Name Protected*}.{*Name Protected*}:{*Name Protected*}'.
ncelab: *N,CUVPRO: For the above CUVMUR error message, the problem occurred in module declared in file /dirction/fc_add_sim_netlist.v.
Can someone give me help on this problem?
05-10-2019 04:26 AM
Hi ljcg100@163.com ,
Did you compile simulation libraries successfully with compile_simlib Tcl command?
Please check comile_simlib logs, are there any errors there?
Please ensure the environment variables are set up correctly.
Also let us know which tool versions are you working with?
Raj
05-10-2019 12:15 PM
Prior to the above suggestions please make sure that you are using the compatible IES version with Vivado. Due to incompatible simulator version too these issues might occur.
