Visitor shumsky
IP behavioral simulation in non-project (batch) flow
I'm running hundreds of simulations in parallel, therefore I'm interested in non project batch simulation flow.
I've successfully used xvlog, xelab and xsim, however no matter what I do - the simulation runs very slow, I think this is due to functional representatino of our IP (mostly coregen generated FIFOs)
I couldnt find any way of what should I do to make a behavioural simultion of those IPs? What should be used for xvlog/xelab?
Many thanks,
Evgeny
Visitor shumsky
Re: IP behavioral simulation in non-project (batch) flow
I'm using vivado 14.1 on centos 64bit
You can try multi thread simulation (-mt) disabpe optimizations (-O).
Check page 102 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug900-vivado-logic-simulation.pdf for details of options available
Thanks,Vijay
