Visitor grpasche
ISE Simulator, internal signals
Is there a way to observe internal signals (signals other than input/output ports. signals that are only visible inside entities) when running a behavioral simulation of a VHDL code?
For example:
entity Trig_S10453 is
  Port ( CLK: in STD_LOGIC;
            ST_CLK: out STD_LOGIC
end Trig_S10453;
architecture Behavioral of Trig_S10453 is
SIGNAL Cpt_intgr: STD_LOGIC_VECTOR (11 downto 0):= x"000";
SIGNAL ST_CLK_INV: STD_LOGIC:= '0';
PROCESS(CLK)
BEGIN
 if (CLK'EVENT and CLK= '1') then
   Cpt_intgr<= Cpt_intgr+1;
end if;
end PROCESS;
ST_CLK_INV<= not CLK;
ST_CLK<= ST_CLK_INV;
end Behavioral;
How I can to observe tne internal signal  "Cpt_intgr" with ISE Simulation
Thanks in advance
Re: ISE Simulator, internal signals
I have the same question. I usually use modelsim for functional simulation. In my design, I am using some IP's from IP Catlog from Xilinx. Hence, I found it better to simulate in Xilinx ISIM. Howver, i was just able to view signal of the top module (all internal signals of sub-modules are hidden). Can I see the internal signals of a submodule ?
Paul
Scholar pratham
Click on + Symbol which is under the objects which is for internal signal.
Pratham
-Pratham
Visitor grpasche
hello,
I tried to used the "Simulate Post-Fit Model", but I do not observe internal signals in the ISE Simulation ?
What should I do to see the "SIGNAL Cpt_intgr".
Thany you for your answer
Grégoire
Paul
Visitor grpasche
I found how to observe internal signal with Xilinx ISim:
In Xilinx ISE click "Simulate Behavioral Model"
In Xilinx ISim, under "Instance and Process Name" click "Name_tbw.vhd" and "uut". Under objects they are internals Signals.
Thank you for your help.
Grégoire
Newbie arundhyani
for internal signals of submodule while simulating a top module ,in xilinx isim
1. first go to instances and processes and choose the submodule from which signal you have tocheck
2,then go to objects you will find all the internal signals
@grpasche wrote:
Grégoire
Newbie arundhyani
‎04-11-2014 04:09 PM
