ISE crash
My ISE 14.7  application crashes and displays the following message on my windows 7 64 bit machine
Problem signature:
Problem Event Name: APPCRASH
Application Name: isimgui.exe
Application Version: 0.0.0.0
Application Timestamp: 525ad4ad
Fault Module Name: libQt_Gui.dll
Fault Module Version: 4.5.3.0
Fault Module Timestamp: 4aefdf6b
Exception Code: c0000005
Exception Offset: 0000000000294809
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: f0f7
Additional Information 2: f0f77e3cc31468627d8aedf1e92bf97f
Additional Information 3: 7175
Additional Information 4: 71758e1867d8d019662f340f55687700
I was hoping some one can help me out
Re: ISE crash
I got it to work. Had to restart my system. Thanks a lot for your help.
Re: ISE crash
Do you have any other ISE installation on the machine?
Vinay
Re: ISE crash
Are you experiencing this crash for other designs as well? Try with some example design and check if it persists. Also you can try with linux OS to rule out possibility of crash being OS specific.
Ashish
Re: ISE crash
Also try below suggestion.
Go to Start --> ISE 14.7 --> ISE design suites 32-bit
Try using 32 bit tool on 64 bit machine.
It may solve the issue.
Yash
Re: ISE crash
No I dont
Re: ISE crash
No I dont have any other version of ISE
Re: ISE crash
Hi So it was working for a design with smaller inputs when I changed the port size it started crashing. I was wondering if it is due to an ISE limitation or a bug in my Test bench as I just changed the port size
Re: ISE crash
Add the switch "-v 1" in the Other Compiler Options property name, under the Simulate Behavioral/Post Place and Route Model properties (make sure the Property Display Level in this property window is set to Advanced). This will enable verbose debugging message and will clarify the cause of problem.
Is it possible for you to share the test design so that we can have a look and comment further?
Ashish
Re: ISE crash
