ISE isim post-x simulation
ISE 13.4 or 14.6 (Only list both as either will do and was wondering if this was depricated in the latest versions?)
VHDL project containg Xilinx IP xores and a ngc file
Am I missing something or where in the gui interface do I go to do a post syntheis or post place and route simulation?  With my top-module highlighted I can generate a model for either but on switching to the simulation view and highlighting my testbench the only process on offer is behavioural simulation (which works fine).
Where do I look or what do I have to do to get post-syth or post-P&R simulation to be an available option?
(For a more global picture, all I want is a vcd (1st choice) or saif file for power estimation)
Re: ISE isim post-x simulation
Check the below snapshot
Thanks!
Don't know how I missed that, too many hours
Visitor kmkhare
When I select Post Map/Post Route simulation option as suggested by you, my test bench vhdl file disappeared and I am able to add it again (it is saying already added in project). and added *_timesim.vhd file Pl.suggest how to proceeed further to do post layout simulation.
