head_up
ISIM (11.4 WebPack): How to make simulation in two time domains?
hi! i have a little problem: I have two time domains and i need to make simulation for two time domains. the processes are independent in every time domain, but there is point where one process must wait other to complete and again to go ahead independent. i write the test bench in this style:
module top_test_2td;
// uut description
initial begin
//simulation code - time domain 1
semaphore_p1 = false;
//here process 1 must wait process 2 to complete first part of simulation
while(semaphore_p2 != true);
//if semaphore_p2 is true - next part of code is executed
semaphore_p1 = true;
end
initial begin
 //simulation code - time domain 2
semaphore_p2 = false;
//here process 2 set flag
semaphore_p2 = true;
//i dont know who of process will complete first and must wait process 1 to complete if process 2 is faster.
while(semaphore_p1 != true);
//ok, process 1 and process 2 are "in time", execute next part of code
end
endmodule
Ok, but simulation stops at  this line (red color in "code"). the process 2 is freeze and never reach this line (blue color in "code"). in my test process 2 look to be slower (absolutely time).
Please, can u help me with some example or explanation how to make semaphore in verilog code or is there some "time/task manager" in ISIM?
Excuse  me for my bad english.
ywu
Try "wait" statement instead of "while". e.g.
wait  (semaphore_p2 != true);
Cheers,
Jim
ywu
Cheers,
Jim
head_up
Thank you, jimwu! wait statement works fine with expression for comparison of bool type and with some little changes in testbench code make it usefull for me. i'm not sure: wait statement will work if the type in expression is not bool? semaphore with more states? i must try... at this time the problem is solved.
