ISIM Lite stops simulation at 1,000 ns
I'm trying out ISIM and have a very simple counter with a clock period of 40 ns.
I have a for loop in the testbench that should produce a simulation into the millisec range but no matter what I do, the simulation stops at 1,000 ns.
From what i've read, ISIM lite is not suppose to have that kind of limitation.
Can anyone suggest what I'm doing wrong or what I need to change within the environment to be able to simulate beyond the 1000 ns limit.
Re: ISIM Lite stops simulation at 1,000 ns
Hi @jhinkle,
You can change the simulation time in Simulation Settings. It's the top field in the Simulation tab of the Simulation Settings window.
Dave
Hi @jhinkle,
Dave
Dave:
Thanks for replying but I must be blind because I can't find what you are stating.
Is the "Simulation Setting Window" part of ISIM or ISE?
I can't see a Simulation tab in either program.
Please help this old squirrel find the nut.
Joe
Finally found it!!!
