ISIM: Search for a value on a data or address bus
Does ISIM have a command that would let me search for a value on a data or address bus?
Why not putting an assertion in your testbench.
This can report all the times that this value occurs in your signal.
Then you can jump to that time in your waveform window.
e.g.:
process(whatvalue) is
begin
  assert (whatvalue /= "XXXXXXXX")
     report "Value x appeared on signal whatvalue"
     severity note;
end process;
Have a nice simulation
  Eilert
In fact, because a concurrent assertion statement is an implicit process, all you need is:
  severity note;
"If it don't work in simulation, it won't work on the board."
Thanks for your answers. Your solution does work perfectly on top level signals of the design. But, I would like to check addresses and the program counter of my simulated processor that is not routed to the top level. In ModelSIM this feature can be found under "Edit - Wave signal search". Note to ISIM developers: Maybe this feature should be added in a later version as it is useful when simulating embedded processor cores.
You can add the assert statements at any level of the design, but if you do, XST will issue warning messages, unless you encapsulate them in the approriate pragmas:
-- synthesis translate_off
-- synthesis translate_on
Of course, in ModelSim you can use SignalSpy functions in the testbench to access signals from any level.
in newest versions of vivado is possible to search for values in vivado simulator window
