ISIM loop unrollment gives multiple drivers?
I have a design and I use ISIM for simulation.
In the code I have the following loop:
for x in 3 to 1 loop
	a(x) <= a(x-1);
end loop;
To my knowledge this will unroll to be
a(3)	<= a(2);
a(2)	<= a(1);
a(1)	<= a(0);
This is used as a synchroniser for clock-crossing. a(0) is assinged a value on the source clock, and the rest is clocked on the destination clock. ISIM however gives no warnings on this, but also does not assign values (all are 'U'). If I unroll manualy (the second code fragment) it simulates as expected. Does anyone have any experience with this problem, if so would you point me in the right direction?
nagabhar
HI @pietervanderstar
Are you seeing this only behavioral simulation alone? is the post translate simulation working as expected?
If its happenning only in behavioral simulation.
Can you try initilize the 'a' std_logic_vector to '0'  or 'Z' and try again?
signal a  : std_logic_vector(3 downto 0):= (OTHERS => '0');
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
nagabhar
Bharath
tusharvi
Hi @pietervanderstar,
I suspect this must be because of
 Please change this to:
for x in 3 downto 1 loop
Let me know if this helps.
Tushar
Please mark the post as an answer ("Accept as solution") in case it helped resolve your query.
Give kudos in case a post guided you to the solution.
This will help others in the long run
Sorry
was a typo in this forum. My code uses downto.
I cannot perform post translate simulation (ISE14.7), but initializing did the trick. I first initialized to '0' but that left one bit with X, so I tried different values. Initializing to 'Z' worked as expected, exept that during reset I assign a (which is an array of an array of std_logic_vectors) as follows:
a(3 downto 1) <= (others => (others => (others=>'0')));
This reset all values exept a(1) this has 'U' on 5 downto 0; This is then shifted out as expected and never to be seen again. It works for my purposes but still a bit strange I think.
nagabhar
Good to know that it worked.
I am  quite sure you will be facing this issue only in behavioural simulation.
std_gloic in VHDL behaviroual simulation is 9 vlaued resolved logic. As resolving 'U' with any value will result in 'U'. it is always safe to initialize signals to '0' or 'Z' in VHDL design .
Bharath
I also use Modelsim (privately) and I have never encountered this issue. Also initializing with '-' resulted in 'U' as well.
nagabhar
 Yes VHDL  behavioural simulation of ISE/Vivado and third party tools might differ in the aspect that the xilinx tools  simulate the signals as 9 valued std_logic elements.
Though I am not quite sure about this, Modelsim/Questasim  converts 9 valued std_logic to 4 valued  net logic(0,1,Z,X) even  at behavioural simulation level to achieve faster simulation. Hence such issues may not arise.
Bharath
That could be though 'U' is given to uninitialized values. But we're drifting off-topic. :)
