ISIM simulation clock problem
In ISIM simulation, why does the clock signal stay low for so long and how to make it return to normal state?
Re: ISIM simulation clock problem
Hi @nia_z ,
I did give a quick try with the shared steps to reproduce and in the above posts, you have mentioned that this clock is a test bench clock. But checking the source code of the top.v file it seems that the clock which you have mentioned is not a test bench clock but the clock generated from the PLL as shown in the below snippet of the code obtained from top.v file
Below is the waveform
回复: ISIM simulation clock problem
How did you specify clock stimulus in test bench?
I don't see anything out of order from the snapshot. Any other factors that may influence the clock toggling?
Can you please share a test case for a look?
Is the clock shown the test bench clock or the output of a DCM?  The DCM will require some time to lock.
Hi @nia_z ,
Can you please share the complete test case or the archived project to check this issue at our end?
Thanks & Regards,
Sravanthi B
The test bench alone cannot be used to reproduce the problem. Please share the entire design so that we can perform the simulation locally and see what the result is.
BTW, in the wave snapshot, is the 'clk' added from the top level or submodule? Is it a behavioral simulation?
The clock signal defined in the simulation module.
I do not observe the same result as what you posted. I just performed top level behavioral simulation and ran the default 1000ns. The 'clk' signal toggles as expected.
Please describe in detail the steps to reproduct the issue.
Hi @nia_z ,
Yes, you are right. And the problem has been solved.
