alangford
ISim - F3 Run All - Doesn't Work
Using Vivido 2017.2 with ISim on Windows 10 ...
The F3 "Run All" shortcut doesn't work on my Vivido 2017.2 instal on Windows 10 ... simple as that ... yet another bug with this tool
Instead it advances the cursor along the line
balkris
i will check on this . Can you please refer page 147 section configuring short cut key. It may help you
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug893-vivado-ide.pdf
Thanks and Regards
Balkrishan
alangford
I should expand ... Im specifically seeing this issue when "debugging" a simulation.
When the focus is the waveform window, the F3 shortcut key does as it should, it continues the simulation
However, when the focus is the text editor where I've hit a breakpoint, pressing F3 doesnt do anything, whilst pressing the "run-all" triangle button does as it should, it continues the simulation.
I have a number of breakpoints in my testbench file. I'd like to press F3 to run from one breakpoint to the next. Instead, I have to press the run-all button within the GUI
Interestingly, the shortcut for "step" = F8 does work
I didnt see anything in ug893 that would help me
