Anonymous
Not applicable
ISim - HwCosim - Add support for new board with one pin for clock
I am starting use of HwCosim.
I have edited hwcosim.bsp to add support for my board.
'MyBorad-jtag' => {
'Description' => 'MyBoard (JTAG)',
'Vendor' => 'Test',
'Type' => 'jtag',
'Part' => 'xc3s500e-4pq208',
'Clock' => {
'Period' => 20,
'Pin' => 'P185',
'BoundaryScanPosition' => 2,
then I read a simple code and testbench,
But I have problem
My design is a hybrid designs and free_running portion of my code need an external clock.
but my borad has one input clock from Pin = P185 that i introduce it as clock in hwcosim.bsp.
when I run compiling for HwCosim i have error.
Error says that I have used all of clock source.
what can I do?
thanks
Anonymous
Not applicable
HI
My problem is exist and I did nir receive any help>
Please help me
Re: ISim - HwCosim - Add support for new board with one pin for clock
hi Razi,
r u using sygen for hardware cosimulation, if yes then tell your vendor from whom u have received the board to provide u with the necesaty bsp's for it i not present and don't try to modify ur existing bsp's as that may give mapping error also..
Best Regards
Chandrajit
Anonymous
Not applicable
Hi Chandrajit
1. I have designed and developed my borad
2. What I understand from xilinx documnet and ap-note that when we want to use a hybrid design
we need two external clock, one for free-running portion of design and one for HWcosim.
But my Board has only one external clock.
hi,
u have to add one more external clock then and change ur bsp's accordingly if u need to run hardware cosimulation.
Best Regards
Chandrajit
Anonymous
Not applicable
HI
thanks for your help.
