Anonymous
Not applicable
ISim ISE147 "ERROR:Simulator:861 - Failed to link the design"
Solution:
installation directory \ Xilinx \ 14.x \ ISE_DS \ ISE \ gnu \ MinGW \ 5.0.0 \ nt \ libexec \ gcc \ mingw32 \ 3.4.2 \ collect2.exe" and delete it and re-run the emulator, the problem resolved! !
thx stackoverflow :
http://stackoverflow.com/questions/23033297/error-in-vhdl-xilinx-failed-to-link-the-design
balkris
Thanks for your concern. check these posts as well
https://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-Simulator-861-Failed-to-link-the-design/td-p/261956
https://forums.xilinx.com/t5/Installation-and-Licensing/Isim-error-861-Failed-to-link-the-design/td-p/507269
https://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-Simulator-861-Failed-to-link-the-design-Windows-7/td-p/475748
Thanks and Regards
Balkrishan
