ISim doesn't work propery when parallel block (fork) is disabled.
Hello, I'm using ISim 14.6(nt64)  P.68d.
This ISim will not work propery when parallel block is disabled.
The fllowing test rtl shows a example.
[ test rtl ]
module TEST_ISIM;
reg    a;
initial begin
    a = 0;
    #10;
    fork
        begin : seq_block0
            #10;
            $display("end of seq_block0");
            disable seq_block1;
        end
        begin : seq_block1
            wait(a);
            $display("end of seq_block1"); // this display will never execute?
        end
    join
    $display("end of parallel_block");
    #10;
    a = 1'b1; // reg a raised here,but seq_block1 is already killed.
    #10;
    $display("finish");
    $finish;
end
endmodule
[ ISim simulation result ]
end of seq_block0
end of seq_block1
finish
[ Simulatioin result with other simulators ]
end of seq_block0
finish
Check this answer record: http://www.xilinx.com/support/answers/36304.html
Vinay
The issue was under investigation and CR was already filed to take care of this problem. This issue seems to be fixed in Vivado Simulator. You can check with latest Vivado version or proceed with the workaround mentioned in answer record pointed by Vinay.
Ashish
This design is working as expected in Vivado 2014.4 XSIM.
Use updated tools for better results.
XSIM output:
end of seq_block0
finish
$finish called at time : 40 ns
Anusheel
Helpful answer -> Give Kudos
Thank you for your responce.
I've understand the current status, and I'll try Vivado vesion.
By the way, I can find same defect with while statement in fork block.
[ sample ]
module TEST_ISIM;
reg    a;
initial begin
    a = 0;
    #10;
    fork
        begin : seq_block0
            #10;
            disable seq_block1;
        end
        begin : seq_block1
            while(~a) #1; // wait statement is changed to while statement
        end
    join
    #10;
    #10;
    $display("finish");
    $finish;
end
endmodule
end of seq_block0
end of seq_block1
finish
[ another simulator result ]
end of seq_block0
finish
not only wait, but also while statement is not supported in fork block ?
Regards.
I checked this with Vivado Simulator (Design Suite 2014.4) and below is the output with while statement
end of seq_block0
finish
Ashish
