ISim hangs up in Elaboration after upgrading to ISE 14.1
Yesterday I was able to run simulations in ISE v 13.x.  I just installed ISE v 14.1.  I wanted to test the installation by running the iSim tutorial with the files I downloaded from xilinx (ug682.zip).  When I get to the point where I launch ISim from ISE ISIM will open but a window with a progress bar on an infinite loop with the message "elaborating" displays for... ever.
I am running Windows 7 32-bit and my machine has4G of RAM.  I am disabling all real-time protection from antivirus and firewall programs to run ISE as this was an issue before (interfered with the PAR execution).
Any help on solving this issue please, would be greatly appreciated.
R
Re: ISim hangs up in Elaboration after upgrading to ISE 14.1
The simulation for ug682.zip works fine at my end.
Is the issue project specific or common? You might open an example design from File > Open Example and have a try.
