wmnedel
ISim simulation and CPU usage
Hello everyone,
is there a way to increase the CPU usage of my simulation? I'm currently simulating a very big project and the simulation tooks hours to complete. I need to run it severel times to get a precise estimation for my research and it's currently not viable to do so.
I'm using ISE 14.6 and the CPU usage for my ISim never exceed 13%. So my question is: There's something I can do to speed-up my simulation?
Thanks in advance
eric_delage
13% Looks like you're simulating w/ only one virtual core on an i7. I'm not sure ISim supports multi-threading. Have a look to the documentation for it. Otherwise switch to XSim incl. in Vivado.
If it's not enough you'll have to have a look to your code and see if your coding style is appropriate. For instance, std_logic_vector are nice but if you simulate some datapath you should better consider using integer range ... to ...
vijayak
ISIM supports multi-threading by default.
Thanks,Vijay
eric_delage
Maybe by default but with 13% CPU usage, he is running with a single processor on an i7 processor (13% CPU usage is the typical value you see in this case). So what could explain, if it's active by default, that it runs on a single processor? Its it only possible if he disabled the multi-threading?
vijayak
with multi threading on by default, and the machine has single processor then the tool will work on single processor only.
Thanks,Vijay
mckinjo4
vijayak,
Are you certain that ISIM uses multi-threading for both compilation and execution?
I've read some support pages that indicate that fuse uses multi-threading and that multi-threading is on by default, but this is just for compilation.
I can't find any references to the simulation executable that gets compiled, for example "mytestbench_isi," using multiple cores. I'm running on a 12 core machine on RHEL6 and when I run the "top" command to look at the processing time, mytestbench_isi sits at 99.7% or 100.1%. I am trying to speed up my simulation and if the executable would use multiple cores it would help immensely.
