pclet
Icarus Simulation Error
The design is targeted by Virtex6-240 device.
I used the Icarus simulator.
That is issued the error.
The error message is
"ISE/verilog/src/unisims/GTXE1.v:2736: error: Unknown module type: B_GTXE1"
What can I do?
Thanks for read.
yenigal
You need to compile the simulation libraries to use the transceivers and also these are only supported by simulators tested and mentioned in the release notes of the tool.
lcarus is not a supported simulator.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Use one of the supported simulators mentioned in the above doc.
Satish
pclet
Thanks for your relpy.
I got it.
