Include .txt files for xsim simulation
Accepted Solution Solved
Accepted Solution
I have files text1.txt text2.txt text3.txt that get read by $readmemh in my testbench. Using the vivado GUI, I get no errors when I manually add these .txt files as simulation source files.
How do I include these files as simulation source files when I'm using the command line (xvlog, xelab, xsim) like I've done using the GUI?
Re: Include .txt files for xsim simulation
When you are using command line, simply copy these text file into the directory where you are running xvlog/xelab/xsim.
All Replies
I suggest you recommend that they use the Vivado run_simulation -scripts_only option to dump compile scripts and see how to set up the libraries as well
Thanks and Regards
Balkrishan
Hi @bfung,
If the simulation is running correctly in the GUI then you can use the command export_simulation to generate a script that will allow the simulation to be run from the command line.
The format is similar to this:
export_simulation -simulator xsim -directory /path_to_where/to_store_files
If you type export_simulation -help into the tcl console it will give you the full syntax.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Thank you @balkris @amaccre @dprasad
These are all good suggestions - but @dprasad suggested what I was seeking (I can't believe I didn't think of this!)
