Inspecting full value of a signal
I am working on a project that includes large bit vectors with > 10k bits. I am looking for a way to see the entire value of the vector in the simulation to be able to verify whether it has the correct value or not. Right now the simulation seems to only show the first 256 hex signs, so the first 1024 bits.
As you can see in the photo the value for test is longer than it is currently depicted.
Does anyone know of a way to change this?
回复: Inspecting full value of a signal
Try to change the array display limit and launch a new simulation.
set_property xsim.array_display_limit size [current_project]
Replace size with your number. By default, it's 1024.
Re: Inspecting full value of a signal
Why such a large array?
Have you tried moving the vertical edge of the signals to the right to make the signals window bigger.
BTW: I have never heard of such a massive vector,
thats amazing,
whats it used for ?
Yes I tried this, I can still only see up to 256 Hex signs.
I am trying to implement an encryption scheme that makes use of a pseudorandom matrix. Each of the rows consists of 16 bit values with >640 values per row, and the rows are generated by hashing a row index||seed, therefore the large vector.
Why cant you just create an array of 16 bit values?
VHDL et all supports multi dimensional structures,
https://www.ics.uci.edu/~jmoorkan/vhdlref/arrays.html
https://www.nandland.com/vhdl/examples/example-array-type-vhdl.html
Its no answer to what seems like a bug ,
but it may be explains why its not been seen before
Yes, that's what I was looking for, thank you very much!
