Instantiated cores undefined outputs
Hello!
I've got problem with simulating my design. It's modified version of PCIE SG DMA project from opencores.
Project consists of VHDL desing and Verilog testbench.
During simulation, *all* FIFO and BRAM cores have undefined outputs (I don't test PCIe core).
Hovewer, simulation script provided with FIFO core works OK (I mean ipcore_dir/fifo/simulation/...).
Additionaly I get some warnings in console when opening project, e.g.:
WARNING:ProjectMgmt - Duplicate Design Unit 'sfifo_15x128' found in library 'work'
WARNING:ProjectMgmt -    "/home/adrian/praca/pcie_dma/ipcore_dir/sfifo_15x128.vhd" line 43 (active)
WARNING:ProjectMgmt -    "/home/adrian/praca/pcie_dma/ipcore_dir/sfifo_15x128_synth.vhd" line 57
and when starting simulation:
WARNING:HDLCompiler:685 - "/home/adrian/praca/pcie_dma/ipcore_dir/sfifo_15x128_synth.vhd" Line 57: Overwriting existing primary unit sfifo_15x128
Cleaning project files or regenerating cores didn't help.
I've got "`timescale 1ns / 1ps" directive in Verilog file and I'm holding reset for 101 ns.
I use ISE 14.2.
FIFO undefined outputs
Is it possible that ISim is picking up wrong files, I mean fifo_synth.vhd instead of fifo.vhd?
Could that be a reason? How to fix it?
Hi@abyszuk,
Did you resolve the problem? I have the same bram output undefined problem except the warning.
