Is VHPI support planned for Vivado ?
I wonder whether VHPI support is planned for the Vivado Simulator.
This is of course very helpful for vhdl based testbenches.
For ISE this was always on the 'roadmap', see
  ISE 13.1 ModelSim Migration Guide
but afaik never materialized.
What are the plans for Vivado ? Does anybody know ?
Currently we are not planning much around VHPI. We have DPI support today, although VHPI is something that is on the roadmap, although I really doubt we will ever do as the demand is not very high for this.
Duth
Currently VPI is in road map.
http://forums.xilinx.com/t5/Simulation-and-Verification/Xsim-IKI-Documentation/td-p/508751
Regarding VHPI I am not sure. But i will post if i find any information.
Yash
I see a product requirement filed for VHPI support but the timeline details are not yet known.
Thanks,Vijay
Duth
I would just like to add my name to the list of paying customers who would like Vivado to support VHPI.
As a European company, all our code is in VHDL, so a VPI interface is useless to us, we need VHPI.
Thank you
[Opinions expressed on this forum do not necessarily reflect the views of Telesoft Technologies Ltd.]
VHPI would be interesting, especially as Modelsim (afaik) doesn't support it. It would allow Python testbenches to be written with cocotb for VHDL, and would provide a good differentiating reason to use Vivado sim.
Advisor
Advisor
VHDL is a very primitive language, especially for file I/O.  I spend much more time translating test data back and forth into VHDL compatible formats than I do working on my design.
One way to alleviate this problem would be to add VHPI to the simulator.  I could feed data in and out of my simulation in convenient full precision formats.  In C, I could directly read and write native Matlab (.mat) data formats.
Today, I needed my VHDL testbench to write 48 bit unsigned numbers to a file, a bloody mess.
In the very early days, before VHDL and Verilog, Mentor Graphics had a C language interface on their logic simulator.  I used that interface to build very sophisticated testbenches for my logic.  In a lot of ways, things have gone backward since those days.
  Pete
DSP in hardware and software
I would also like to add my name to this list. As ModelSim doesn't support VHPI, it will be a major motivator for me to use ISIM if it supports VHPI.
VHDL is a great language, and can be as high level as C in my opinion. One can code in a high-level "abstract" way, or code in a more primitive low-level way. VHDL is very flexible in this sense.
However, I still find myself needing to interface VHDL with other languages, mainly for verification purpose. Because many models are frequently provided in languages such as C or Matlab, while implementing these models in VHDL, there is always a need to verify correctness against the original (golden) model. Rewriting the models in VHDL would most likely allow unintended mistakes to creep in, therefore we would like to use vendor-provided models directly in our verification flow. This is where we need VHPI.
-dan
