Visitor thepete5
Is there a way to reset/remove/delete simulation files within a project?
In a typical Vivado project (project mode), I can clear an implementation or synthesis run quite easily by right clicking the appropriate icon in the flow navigator and "resetting" the run. When I run behavioral or post-synthesis simulations, I don't really see this option. Normally, it's not a big deal, but on some larger projects, a post-synthesis functional or timing simulation can generate approximately 1 GB of files! I won't pretend that I'm an expert at design, so maybe these simulations shouldn't generate such large files. But sometimes simulations are a great way for me to debug my designs by tracing signals.
The large number of files show up in the automatically generated folders: [project_name]/[project_name].sim/sim_1/
(then, behav for behavioral and synth for synthesis). After I clear/reset a synthesis run, the simulation files remain.
Is there a way for me to delete these files? It would be nice to have the option to delete them when I'm done with a simulation since I sometimes back up my files and all of a sudden there are a lot more files than anticipated. I didn't see much on the forums and I scanned and read some manuals and either I completely missed it or I couldn't find it. I currently manage this by deleting the folder manually, but sometimes I worry that I will end up deleting some necessary files or files that Vivado will complain are missing next time I open the project.
Any help would be greatly appreciated! I am using Vivado 2014.4 (sometimes on Windows7, sometimes on Linux-CentOS)
Thanks in advance if anyone can help.
Re: Is there a way to reset/remove/delete simulation files within a project?
Are you looking for "reset_simulation" command?
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
There is no option to reset the simulation runs similar to synthesis and implementation.
The workaround is to use tcl command to delete the files. i.e., file delete -force xsim.ini
Vinay
Have you tried reset_project tcl command. For more details run reset_project -help in vivado tcl console.
Deepika.
Deepika.
Anusheel
Hi @thepete5
Did you get the info you are looking for?
Deepika.
Deepika.
Visitor thepete5
Thank you all for the help! I didn't think to use the tcl commands (my apologies, I'm still pretty new to Vivado!).
