Is there a way to stop generate waveform file (.wdb file) in vivado simulator?
Hi ,
 I want to output my result through $fdisplay the data to a   .txt file.
The data size is huge and simulation time is very long.
I am thinking if the vivado simulator could stop generate the .wdb(waveform data base) file, may the simulation time will be faster.
Is there a way to stop the simulator from generating the wave file?
Any hint will be appreciated!
Re: Is there a way to stop generate waveform file (.wdb file) in vivado simulator?
[ Edited ]
@mathmaxsean,
Did you try by completely removing the .wcfg files from your project?
Avi Chami MSc
FPGA Site
You can use $finish or $stop in your simulation testbench
Thanks and Regards
Balkrishan
