Participant alexis_jp
Is there any default configuration file similar to modelsim.ini for Vivado?
I'm tired to set manually everything when I generate Example design or setting up the simulator adding `-32` in every vlog/com.. and so on; either in the GUI or TCL.
Is there any default tcl/config file that will be used to configure all the new projects?
Thank you.
Re: Is there any default configuration file similar to modelsim.ini for Vivado?
Hi @alexis_jp ,
There isn't a default config file for Simulation thats an equivalent to modelsim.ini, but there is the vivado_init.tcl file that is read when Vivado starts and can be used to set default parameters and switches.
You can find further information on this in UG894:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug894-vivado-tcl-scripting.pdf
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi @alexis_jp ,
Best Regards
Aidan
Perfect! Thank you!
Hi @alexis_jp ,
If your query is addressed then can you please close this thread by marking the post which helped as accepted solution.
Thanks & Regards,
Sravanthi B
