Issue while trying to simulate post-synthesis model
I try to simulate post-synthesis model in Vivado 2018.2. I use my testbench that I used when simulate behavourial model but can't to stimul signal. Below there's my waveform. Thanks in advance for your help.
Re: Issue while trying to simulate post-synthesis model
Hi @8150179miet ,
Can you please share the archived project to check this issue at our end ?
Thank you for help. I found error myself. I tried to create netlist from my block design file. I replaced block design file with verilog file so it has worked.
Hi @8150179miet ,
Glad to know that you were able to solve this issue. Can you please close this thread by marking your post with solution as accepted solution.
Thanks & Regards,
Sravanthi B
