Issue with assignment string parameter with escape characters to signal
I checked issue with Vivado Simulator 2015.4 and 2016.4. Modelsim and Aldec do not have such problem.
Simple SV example:
parameter STR = "A\\nB";
wire [$size(STR)-1:0] str_i = STR;
Both STR and str_i have size 32. Hex representation of STR is 0x415c6e42 (4 symbols: A\nB). So, dual backslash is correctly translated to single in STR. But str_i is 0x00410a42. It seems that second translation of escape character (\n to 0x0a) was performed in the wire assignment. With the direct assignment str_i = "A\\nB" behavior is the same.
It works fine when wire is changed to logic (so, assignment is changed to initialization):
// Both STR and str_i are 0x415c6e42
logic [$size(STR)-1:0] str_i = STR;
And finally working example
// STR, str_i and str_i2 are 0x415c6e42
wire [$size(STR)-1:0] str_i2 = str_i;   // or logic
Re: Issue with assignment string parameter with escape characters to signal
Hi @5506273,
This is bug in Vivado simulator, Issue(CR969375) reported to the factory.
Sunilkumar
Hi @5506273,
Sunilkumar
