Keep multi-dimensional arrays from generate of multiple modules in netlist via 'write_verilog'
I have a systemverilog module I wish to simulate post-synthesis and post-implementation with Vivado 2017.2 using the write_verilog tcl command.
The DUT top module is parameterised and this parameterisation generates 3 instantiations of another module. The outputs of which are arrays and so go into 2D multi-dimesional arrays ports on the top module.
Vivado appears to escape these multi-dimension arrays into separate ports. Hence ports in the RTL like..
   output logic [2:0] [31:0] m_axis_tdata,
..in the netlist become..
    output [31:0]\m_axis_tdata[2] ;
    output [31:0]\m_axis_tdata[1] ;
    output [31:0]\m_axis_tdata[0] ;
..I've found the following previous post but the answer is useless..
    https://forums.xilinx.com/t5/Synthesis/Keeping-port-name-same-after-synthesis/td-p/844752
....Steve
I'm afraid multi-dimensional array has to be expanded to vectors in synthesized netlist.
