Visitor zhangka12
MMCM_ADV
Hey all, I have this bluespec code that incorporates a core generated by Xilinx. This core used by Xilinx uses a Xilinx primitive called "MMCM_ADV".
When I simulate the code on ISIM, the design works perfectly.
However, when I try to then simulate it in model sim, it doesn't work. I've narrowed (at least) part of the problem down to this Xilinx primitive MMCM_ADV. It has 3 inputs (which I confirmed is being inputted correctly) and multiple outputs. I've noticed that the outputs from this modules are incorrect (Z or X) when simulated from modelsim but not in ISIM even though I've confirmed that in both cases, the inputs are all the same.
Additionally, I know that I linked Xilinx's verilog primitives path to modelsim such that modelsim knows where to search.
Also, I found that I have modelsim 6.4b, which is the minimum version needed according to XIlinx: http://www.xilinx.com/support/documentation/ip_documentation/mmcm_module.pdf
Anyone encountered a similar problem to this and knows how to solve it?
Tags (3)
Re: MMCM_ADV
How did you "link Xilinx's verilog primitive path to Modelsim"? Did you run simulation in Modelsim standalone? What command did you use?
If you have pre-compiled Xilinx simulation libraries, please make sure "unisims_ver" library is referenced in vsim command.
Visitor zhangka12
Re: MMCM_ADV
By "link Xilinx's verilog primitive path to Modelsim", I mean that under the Xilinx folder, I found verilog files for some of the Xilinx primitives such as MMCM_ADV under the folders:
verilog/xeclib/unisims
and
verilog/src/unimacro
As such, I included the directories above as libraries to look into when I generated the modelsim binary executables.
However, it seems that when I try to look at those primitive verilog files, all those files contain are the inputs/outputs declarations but none of the actual logic.
Re: MMCM_ADV
You referred to the wrong directory. The MMCM_ADV primitive is located at $XILINX/verilog/src/unisims.
