Memory Declaration and instantiation
In my high level design I instantiated memory which would take a contantenate signal from two counters, but I'm getting all sort of errors such as the following:
I've also attached my high level vhd file wich comprises the component declaration and instantiation.
ERROR:HDLCompiler:69 - "/../clock.vhd" Line 85: <wea> is not declared.
ERROR:HDLCompiler:69 - "./../clock.vhd" Line 86: <addra> is not declared.
ERROR:HDLCompiler:69 - "../clock.vhd" Line 87: <addrb> is not declared.
ERROR:HDLCompiler:69 - "/../clock.vhd" Line 88: <dina> is not declared.
ERROR:HDLCompiler:69 - "/../clock.vhd" Line 89: <doutb> is not declared.
ERROR:HDLCompiler:192 - "/../clock.vhd" Line 89: Actual of formal out port doutb cannot be an expression
ERROR:HDLCompiler:854 - "/../clock.vhd" Line 28: Unit <structural> ignored due to previous errors.
Re: Memory Declaration and instantiation
Hi @serge1973,
Try with the following code.
You have not declared wea,addra,addrb,dina,doutb in top module.
So during port map tool is throwing these errors.
Added the following lines to top module
signal wea : STD_LOGIC_VECTOR(0 DOWNTO 0);
signal dina : STD_LOGIC_VECTOR(15 DOWNTO 0);
signal addra : STD_LOGIC_VECTOR(3 DOWNTO 0);
signal addrb : STD_LOGIC_VECTOR(3 DOWNTO 0);
signal doutb : STD_LOGIC_VECTOR(15 DOWNTO 0);
Please try with the attached .vhd and let us know the outcomes.
Arpan
Arpan
Hi @serge1973,
Which version of tool and the target device you are using?
Arpan
Arpan
Hi @serge1973,
You need to declare those as signals in your design with the width equivalent to what it is port-mapped to because they are not connected to any top-level ports.
Use the attached file.
Rajesh
Hi @arpansur,
ISE 14.5 and I will be targetting Basys 2 board.
Thanks!
Hi @rajeshtu,
I don't quite follow your response. I generated the block memory using the core generator within ISE14.5 tools which created some folder and vhd file. And like counters I thought I would do the same for the memory block by declaring its components and then instantiate them.
Hi @serge1973,
Arpan
Arpan
Hi @serge1973,
You have missed out the signal declarations in the code.
Please use the file attached above.
(When you instantiate a particular component in a design, then its ports must have either some connection to the top level (ports or signals) or it can be tied to any static value)
Rajesh
All errors are gone. Thanks!
Do you think this part of the code is accurate? I've commmented out because I was also getting an error.
signal memory_address : std_logic_vector(15 downto 0);
memory_address <= address_h & address_v;
Thanks! It's working now.
I'm getting the following error I run the simuation
ERROR:HDLCompiler:288 - "./../clock.vhd" Line 96: Cannot read from 'out' object address_h ; use 'buffer' or 'inout'
ERROR:HDLCompiler:854 - "./../clock.vhd" Line 28: Unit <structural> ignored due to previous errors.
Hi @serge1973,
You declared address_v and address_h as output but you are using it is as input in the following line
That's the reason tool is throwing error.
So please change the declarations from out to inout and let us kow.
address_h : inout std_logic_vector(7 downto 0);
address_v : inout std_logic_vector(7 downto 0);
Please try with attached .vhd and verify if you are getting the same error or not.
Arpan
Arpan
You're correct. Thanks a bunch!
Hi @serge1973,
Glad to know your issue is resolved.
Just a suggestion:
It's good forum practice to create a new thread for different error message with subject as exact error message. It will be helpful for others having similar issue.
Arpan
Arpan
Understood.
Thanks!
