hisleo
Mig 7 Series example simulation fail
I generate IP MIG (V7) for my design(2014 / 2016/2017, 3 versions of vivado tried).
For the example design, if I simulate by vivado itself, it is pass;  but if I simulate by VCS or IRUN, it failed on pi_phaselock_err.
I could not find out the reason. Can anybody meet this problem?
3Q
hisleo
Finally, the problem was resolved. The reason is cause by my makefile, VE add incorrect option "+delay_mode_zero" whcich cause the error
thakurr
Hi @hisleo
What exactly the error you get while simulating in VCS or IRUN?
Rohit
Rohit
hisleo
init_calibrate fail. I did basic waveform debug, find timeout when calibration fsm_state is 0x26.  Right FSM jump condition should  phaselock is high, but need appear.
And when calibration start, most signal for ddr interface is still x state.  And from the waveform, I can watched that the input signals for phy_top is same for VCS and xsim simulation.
I would past waveform and log next monday
vemulad
Hi @hisleo
Try running the scripts ies_run.sh/vcs_run.sh located in project_1/mig_7series_0_example/mig_7series_0_example.srcs/sim_1/im
ports/sim folder.
Ensure that the version of VCS/IES used is supported with Vivado. Refer to vivado install and release notes for details.
Deepika.
hisleo
