lifeatthesharpend
Mixed VHDL verilog simulation with Vivado scope issue
When I run the vivado simulator (2014.2)  and undock the waveform window I can not use the right / left / up /down keys when navigating the waveform.
When the window is docked it works correctly.
Is this a known issue and is there a fix?
L
