eserica
ModelSim ALTERA Starter Edition 10.1d ** Error: (vsim-3170)
Hello
I am working on the implementation and simulation of an aes_core using Xilinx-ISE Design Suite 10.1 and ModelSim ALTERA Starter Edition 10.1d.
When  Simulating the Behavioral Model I receive the error:
# -- Loading package std_logic_1164
# -- Loading package NUMERIC_STD
# -- Loading package avs_aes_pkg
# -- Compiling entity AES_CORE
# -- Compiling architecture arch1 of AES_CORE
# -- Loading entity Shiftrow
# -- Loading entity Mixcol
# vsim -lib work -t 1ns AES_CORE
# ** Error: (vsim-3170) Could not find 'C:/Users/Eserica/myproject/work.AES_CORE'.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./AES_CORE.fdo PAUSED at line 39
VSIM(paused)>
Actually, my project resides in the library avs_aes_lib not in work.
How do I fix this?  Any ideas?
austin
e,
Are you asking Xilinx to fix someone else's software?
That is not our problem.  You should be using Xilinx software!
Austin Lesea
Principal Engineer
Xilinx San Jose
debrajr
If you are facing similar error if using Xilinx ISE Simulator then post back. We can only provide answers to Xilinx Supported Simulators:
a) Modelsim SE/PE/DE/XE
b) Cadence NCSIM
c) VCS
Debraj
eserica
Ok.
Noted with thanks
