[ModelSim] how to run a bash script from within ModelSim?
Hi All,
I'd like to run a bash script from within ModelSim. How can I do so?
Thank you!
Scholar jmcclusk
Re: [ModelSim] how to run a bash script from within ModelSim?
Ah!   you didn't say this was Ubuntu on Windows 10!    you need to search for the file,  "bash.exe" and provide that in your command to exec..
This might work:
exec  "C:\\Windows\\System32\\bash.exe a.bsh"
If this doesn't work, try this form:
exec  "C:/Windows/System32/bash.exe a.bsh"
you might not need the explicit path to bash if you already have bash.exe in your windows path environment.
Scholar jmcclusk
Use the TCL EXEC command to invoke a subprocess.   You should be able to call a bash script using EXEC
OK, I tried this command ...
I created a bash script, which just echo some string.
But when I call to this script, I'm receiving the following:
%> exec a.bsh
%> couldn't execute "a.bsh": no such file or directory
When I check whether the file script exist, it does:
%> ls a.bsh
%> a.bsh
So, what's the problem? All the above commands were run from the ModelSim Transcriptt window.
Scholar jmcclusk
try  exec "./a.bsh"  and also make sure that a.bsh has the execute bit set.  "chmod +x a.bsh"
this is a Windows 10 with Ubuntu on-board...
How can i use chmod+x for window?
The ModelSim is running on Windows ....
Scholar jmcclusk
This might work:
"you might not need the explicit path to bash if you already have bash.exe in your windows path environment" - how can I add this path to the window path environment?
