davelinney
Modelsim Library mapping empty
Hi Guys,
Having problems getting Modelsim to instantiate components from the Kintex7 libraries.
Am using;
    ModelsimDE-64 10.4c
    Vivado v2017.4
Have compiled the libraries to path C:\Users\David.Linney\Design\Kintex\libraries\libraries.cache\compile_simlib
Added library mappings to the Modelsim project by inserting mapping into the .mpf file eg.
     simprims_ver = C:/Users/David.Linney/Design/Kintex/libraries/libraries.cache/compile_simlib/simprims_ver
     secureip = C:/Users/David.Linney/Design/Kintex/libraries/libraries.cache/compile_simlib/secureip
simprims works, secureip shows as empty.
Screenshots
About the only difference I can see between the contents of the two library folders is that secure_ip does not have a _vmake file.
Have recompiled and remapped but no difference.
Any Ideas?
Thanks in advance
Dave
thakurr
Hi @davelinney
Can you tell us what exact command you use for compiling the libraries? Make sure the simulator executable path is correct while you run this command.
compile_simlib -simulator modelsim -simulator_exec_path {C:/modeltech64_10.5c/win64} -family all -language all -library all -dir {<project_path>/.cache/compile_simlib}
Also please note that  ModelsimDE-64 10.4c is not supported version with Vivado 2017.4. You need to upgrade the modelsim version to ModelSim SE/DE/PE (10.6b) or any version higher to this. Refer below link, page 11:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug973-vivado-release-notes-install-license.pdf
Rohit
Rohit
davelinney
P.S. There was supposed to be another image on the original post
Screenshot
thakurr
Hi @davelinney
Rohit
Rohit
davelinney
Hi Rohit,
Thanks for quick reply.  Have been in discussion with our Mentor supplier.
Compiled libraries from Vivado GUI.
Didn't specify simulator exe path but when I do it's rejected (10.4c not supported).
Don't want to spend a fortune on Modelsim 10.7 only to find that it works no better.
Saw this from our support guy;
   "No Modelsim 10.7 does not work with Vivado 2017.4, it fails when you run compile_simlib, it is expected to work with the upcoming Vivado 2018.1 release which should support all the latest versions of EDA tools."
In meantime I've been trying to get the Vivado simulator going but will open a new thread for that.
Dave
