Monitor signals in mixed VHDL/Verilog environments in Verilog testbench
I have a testbench where the testbench is written in Verilog and my component is written in VHDL. The hierarchy looks like this:
Testbench (Verilog)
|- Block design
  |- Component (VHDL)
I've tried to access the signal using the hierarchical name but this will generate the following error:
Cross Language Hierarchical name(ssram_if_bfm_tb.inst_ssram_if.ssram_if_tb_i.ssram_if_top_0.U0.blk_ssram_data_mirror.inst_data_mirror.inst_synchronous_fifo.cnt) is not supported in this context.
Is there a way to monitor the signal from within my testbench?
Martin
Re: Monitor signals in mixed VHDL/Verilog environments in Verilog testbench
There are few limitation when using Mixed language simulation.
A Verilog hierarchical reference cannot refer to a VHDL unit nor can a VHDL expanded or selected name refer to a Verilog unit.
However, Verilog units can traverse through an intermediate VHDL instance to go into another Verilog unit using a Verilog hierarchical reference.
Details can be seen in page 159, http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug900-vivado-logic-simulation.pdf
Debraj
Debraj
Hi Debraj,
thank you for your explanation! Too bad this isn't supported.
