beandigital
Multiple issues with Vivado 2020.1 sim
I am seeing with a few issues with the Vivado simulator. I have a VHDL design an at times I am finding that if I make changes to the design, such as add another port to an entity, that the simulator doesnt pick up the changes. It just has the signal as U. If I then close the project and delete the sim dir then start it back up, everything works fine. I am also seeing issues with if I restart the simulator then Vivado just suddenly crashes. I see this maybe 4 or 5 times per day. Does Xilinx know what is causing these issues?
miti
1. After updating the source files please use laucnh_simulation, it should take all the changes.
2. Can you let us know which vivado version/ OS you are using, if possible please share the project /testcase here.
