Visitor bojan90
[NCSIM][ISE] Unit (VCOMPONENTS) not found in library (UNISIM)
I'm having an issue, with error from subject.
I've compiled HDL libaries from ISE GUI for NCSIM, and then runned simulation from NCSIM, and I have got this error several times.
Also, my Compilation log summarizes 3 errors in Unisim, 2 error in simprim, 1 error in xilinxcorelib, and 184 in edk (I'm not using edk), all these in vhdl, verilog libraries doesn't have any errors. And i got only warning sign in process tab.
I'm using 14.1 Incisive and 14.7 ISE.
Also I'm trying to run simulation with -irun, is this even possible, or I'd have to use commands as specified in ARs?
Thank you in advance
Bojan
Re: [NCSIM][ISE] Unit (VCOMPONENTS) not found in library (UNISIM)
Can you try to check if the ncsim environment is properly set. Is the file cds.lib along with cdsvhdl.lib files present at the location: 12.20.016/tools.lnx86/inca/files? If not then you might have to re-install the tool and set the environment properly.
Debraj
Hello Bojan,
From the error message, I think the issue is: tool was unable to see the compiled libraries.
Try copying the cds.lib file to ISE project directory or to present working directory. So that when you run the command: irun, it will pick the compiled libraries.
Vinay
Hello @bojan90,
Make sure you are using a supported version of Incisive with ISE 14.7. Check the following release notes at page number for supported third party tools with ISE 14.7.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Syed
Hi @bojan90,
Also check Appendix B at page number 163 in the below UG for simulating Xilinx designs in Incisive simulator.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/sim.pdf
Syed
Visitor bojan90
Hello @syedz
In compatible third party tool table, there is only 12.20.016, is it possible, that newer tool can't simulate design?
Scholar pratham
@bojan90 Yes, User guide shows the lowest version limit. I don't think so there will be any problem using updated version of the tool
-Pratham
Visitor bojan90
I've made another design (AND circuit), done everything from begining, and I have the same mistake again.
Visitor bojan90
Also when I do compXLib compilation, I get this error:ncvhdl_p: *F,NOLSTD: logical library name STD must be mapped to a design library [11.2].
Debraj
Visitor bojan90
Yes they are...
I've solved it, it is necessary to have INCLUDE $INCISIV141/tools.lnx86/inca/files/cds.lib
in cds.lib when you start your CompXLib, and then everything works...
Thank you guys :)
