Not getting output for CORDIC program implemented
Given below is program to for unscaled sine value generation using CORDIC .
There is no errors in my program but still getting output as illogical value.
I have attached program code and testbench i have written as well as output waveform i am getting.
Kindly check and tell suggestions
HI shilpa@0484 ,
It seems that there is another issue in TB as the clock period is 10ns and the signals will not get initialized in DUT if the start signals toogles just after 5ns. So, increase the start signal toogle time from 5ns to 15ns by below modifications and see if it helps
initial begin
// Initialize Inputs
clk = 1'b0;
start = 1'b1;
angle = 0;
#15 start=1'b0;
Hi shilpa@0484 ,
You have specified the signal start to be 1 after 5 ns due to which the else condition will not get triggered. So, modify the code as below in TB and check if it helps
initial begin
clk = 1'b0;
start = 1'b1;
angle = 0;
#5 start=1'b0;
No it didn't work
Signals are active low only
HI shilpa@0484 ,
initial begin
clk = 1'b0;
start = 1'b1;
angle = 0;
#15 start=1'b0;
Thanks for support!!!!!!!!!
