Open ISIM command prompt
Hi every body
How can I use the ISIM in command prompt in termina ?! Like when you use the -gui switch the ISIM GUI is lauched and the ISIM command prompt is opened in the console. Like following :
ISim>
I'm using ubuntu 10.04 & ISE 13.3.
Thanks in advance
Re: Open ISIM command prompt
You can enter commands in Interactive Command Line Mode by running the ISim simulation executable that you generated from fuse at the command line,
for example,
my_sim.exe
A Tcl prompt appears:
This is a Full version of ISim.
Time resolution is 1 ps
ISim>
for example,
my_sim.exe
ISim>
This is very stange. I tried it several times before and it did not work. Is this available in the WebPack edition ?
Another question, When generating executable with fuse, should i use the prj method ? Or can i compile files using the vhpcomp method ?
Thanks in advance
I have another question, Is there any tips to reduce the runtime for a simulation ? If using the full version. ISIM is still very slow compared to modelsim.
It is recommended to use .prj which lists the source files.
Another way is to run vhpcomp to parse the design files and then fuse to generate simulation executable.
I don't think WebPACK has limitation in this. What is returned in command line when you run xxx.exe?
I run the .exe file in the terminal without -gui. It waits for some time expecting to open the ISim> but it returns to the normal bash command prompt. But now it's running. I had problem with some libraries, looked the internet and found the solution here
