Open waveform config file in vivado
I searched the answer of course in the forum.
In this solution doesn't my answer
http://www.xilinx.com/support/answers/64116.html
I want to open directly last waveform without say run simulation in vivado. Because this take again extra time and start only simulation doen't show last window.
I want to see my last window speedly?? Also,
I wanto save waveform to jpeg,pdf.. Is it possible this inside from vivado??
thanks
Re: Open waveform config file in vivado
For that you need the .wdb and .wcfg file and you can follow the steps below:
1. Open Vivado GUI.
2. In the TCL console, type: cd {to the path where .wdb & .wcg is present}
3. Type: current_fileset
4. open_wave_database xxxx.wdb
5. open_wave_config xxxx.wcfg
And, it is not possible to save the waveform in jpeg or pdf. You can create a VCD file if that helps you from Vivado.
Debraj
1. Open Vivado GUI.
Debraj
Thank you, I didn't stay tuned.
