Newbie guelm
Order of operands in simple signed addition
I have a very simple,combinational signed addition component. Code is below;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity adder is
    Port ( op1 : in  signed (31 downto 0);
           op2 : in  signed (31 downto 0);
           res : out  signed (31 downto 0));
end adder;
architecture RTL of adder is
begin
res <= op1 + op2;
end RTL;
When simulating, I observe a very peculiar behavior. If I assign values as :
op2<=X"00000000";
op1<=X"11111111";
I get the correct result; res = X"11111111"
However,when operands are changed so that
op1<=X"00000000";
op2<=X"11111111";
I get a completely different value; res = X"eeeeeeef", which is the correct result but signed conversion applied. Why does order of operands matter, or is this some sort of bug on the tool, since I use last version of ISim on Windows 10.
Thanks!
Re: Order of operands in simple signed addition
Can you post a screenshot of the simulation waveform for both cases and snippet of your TB driving op1/op2?
www.xilinx.com
Newbie guelm
Here is the testbench;
 LIBRARY ieee;
  USE ieee.std_logic_1164.ALL;
  USE ieee.numeric_std.ALL;
  ENTITY adder_tb IS
  END adder_tb;
  ARCHITECTURE behavior OF adder_tb IS
  -- Component Declaration
          component adder
end component;
          SIGNAL op1 :  signed(31 downto 0);
			 SIGNAL op2 :  signed(31 downto 0);
			 SIGNAL res :  signed(31 downto 0);
  BEGIN
  -- Component Instantiation
          uut: adder PORT MAP(
                  op1 => op1,op2=>op2,res=>res
  --  Test Bench Statements
     tb : PROCESS
     BEGIN
        op2<=X"00000000";
		  op1<=X"11111111";
		  wait ;
		end process;
  --  End Test Bench
  END;
Here are the screenshots;
Thanks!
