wyatt_ogden
Output of Floating Point IP result tvalid is 'X'
Hey everyone,
I'm trying to get a simple testbench for the floating point IP to work to see how I can integrate it into my own, but I seem to be having some problems.
NOTE: I cut out the answer in the screen shot :(. But it does in fact return 01! Which is expected
Here is the waveform image. I simply compare the value of 10 with 10 and perform an is == operation. The answer seems to be correct but for some reason the tvalid signal is showing up as undefined instead of as a logical high as stated in the data sheet.
Here's the test bench I'm driving with.
module fp_tb(
    reg [31:0]M_AXIS_A_tdata_tb;
    reg M_AXIS_A_tvalid_tb;
    reg [31:0]M_AXIS_B_tdata_tb;
    reg M_AXIS_B_tvalid_tb;
    reg [7:0]M_AXIS_OPERATION_tdata_tb;
    reg M_AXIS_OPERATION_tvalid_tb;
    wire [7:0]M_AXIS_RESULT_tdata_tb;
    wire M_AXIS_RESULT_tvalid_tb;
    reg aclk_tb;
    reg aclken_tb;
    reg aresetn_tb;
    fp_design_wrapper DUT
        .S_AXIS_A_tdata(M_AXIS_A_tdata_tb),
        .S_AXIS_B_tdata(M_AXIS_B_tdata_tb),
        .S_AXIS_B_tvalid(M_AXIS_B_tvalid_tb),
        .S_AXIS_OPERATION_tdata(M_AXIS_OPERATION_tdata_tb),
        .S_AXIS_OPERATION_tvalid(M_AXIS_OPERATION_tvalid_tb),
        .M_AXIS_RESULT_tdata(M_AXIS_RESULT_tdata_tb),
        .M_AXIS_RESULT_tvalid(M_AXIS_RESULT_tvalid_tb),
        .aclk(aclk_tb),
        .aclken(aclken_tb),
        .aresetn(aresetn_tb)
    task clk_tick;
        begin
            aclk_tb = 0; #1;
            aclk_tb = 1; #1;
        end
    endtask
    initial
        begin
            aresetn_tb =0;
            M_AXIS_A_tdata_tb = 0;
            M_AXIS_B_tdata_tb = 0;
            M_AXIS_A_tvalid_tb = 0;
            M_AXIS_B_tvalid_tb = 0;
            M_AXIS_OPERATION_tvalid_tb = 0;
            M_AXIS_OPERATION_tdata_tb = 1;
            clk_tick;clk_tick;clk_tick;clk_tick;clk_tick;clk_tick;clk_tick;clk_tick;clk_tick;
            aresetn_tb = 1;
            clk_tick;
            clk_tick;
            aclken_tb = 1;
            clk_tick;
            M_AXIS_A_tdata_tb = 32'h0x41200000;
            M_AXIS_B_tdata_tb = 32'h0x41200000;
            M_AXIS_A_tvalid_tb = 1'b1;
            M_AXIS_B_tvalid_tb = 1'b1;
            M_AXIS_OPERATION_tvalid_tb = 1;
            M_AXIS_OPERATION_tdata_tb = 8'b010100;
            while(1)begin
                clk_tick;
            end
            aresetn_tb = 0;
            clk_tick;
            clk_tick;
            clk_tick;
        end
endmodule
I've also tried this same test with the addition module and cannot get result_tvalid to go high instead of undefined.
What's going on here?
bandi
Hi @wyatt_ogden,
Can you please share the archived project with the .xci file to check at our end.
Thanks & Regards,
Sravanthi B
andrewlan
Could your problem be due to aclken_tb being at an undefined state earlier in your sim during the reset period? That does not look right and I would add a line after "aresetn_tb =0;" setting this signal to a defined state.
