Outputs of module having unknown logic values
Hey everyone, I don't know why my outputs keep having unknown values. I'm building a circuit that carries out the Collatz procedure; it keeps going on if there is no overflow or the input isn't 1. I've tested the combinational block and it works fine. In the combinational module, end and over are declared as outputs. So, I've instantiated an instance of that in my sequential module. This time though I want the output of my sequential block to output the sequence of computation once it terminates. But I still want the outputs of end and over to display in my sequential output and I'm having trouble getting this right. I've tried declaring it as both reg and wire, but nothing comes up on my outputs. Here is my code:
module collatz_sequential(
    input [7:0] X,
    input Clock,
    input Start,
    output [7:0] C,
    output End,
    output over
    wire [7:0] driver;
    wire [7:0] selected;
    wire [7:0] out;
    wire signal_end, signal_over;
    reg END, OVER;
    reg [7:0] C = 8'b00000001;
    wire start;
    reg startn;
    wire clrn = 1;
    assign start = Start;
    assign signal_end = End;
    assign signal_ = over;
    always@(*)begin
    assign END = signal_end;
    assign OVER = signal_over;end
    assign clrn = ~( END | OVER ) | start;
    parameter reset = 0, processing = 1;
    reg state = reset, nextState;
    mux_8bit input_select (out, X, start, selected);
    parallel_8bit_reg register (selected, Clock, clrn, driver);
    collatz_comb comb_Part (driver, out, End, over);
    always@(*)begin
    if ( END || OVER )begin
    nextState = reset;end
    else if (start)begin
    nextState = processing;end
    end
    always@(posedge Clock)begin
    state <= nextState;
    if ( state == processing )begin
    C = C + 1'd1;end
    end
    always@(negedge Clock)begin
    if(start)begin
    startn = 0;end
    end
    assign start = startn;
endmodule
Any thoughts? I'm new to FSM too so is it an error elsewhere? Thanks!
Re: Outputs of module having unknown logic values
Hi @limxx518,
Just looking at the output "End". You are never giving it a values. The only thing that you are doing is reading it:
Why did you declare it as output if you are reading it? It should be an input...
Re-do your FSM step by step and it will work if you are careful...
Florent
Florent
Hi @florentw, thanks for your reply! I want to read it and output it as well. So End should be the output from my collatz_comb module. And if end or over isn't zero, I would want the output from the collatz_comb module to be computed again. However, if end or over is zero, I want to feed the outputs of the collatz_comb module to the outputs of my sequential module.
That's why you see that End and over in the instantiation module of collatz_comb is the same as the outputs in my sequential module. Is it possible to do that?
Since I also want to read the outputs of the comb circuit to determine the state of my FSM, I declared END and OVER as regs, since they are the data type that can store values.
I've included a pic of the description to make it clearer
TLDR; I want end and over to be outputs as well as values that can be read to determine next states of FSM.
Hi @limxx518,
I don't really know for verilog. You should create a wire it should be clearer.
You might want to show what your waveform looks like.
Florent
Florent
Hi @florentw, so I've did as you suggested, namely I assigned the outputs of the comb module to a wire instead. It still isn't working though. Here are the assignment changes I made:
EDIT 1: I realise I can't assign that as a wire, for I can't read values from a wire, can I? It seems that the implementation of my FSM needs to be changed.
EDIT 2: No,  I think it will work if I assign values of signal_end and signal_over to reg values END and OVER in an always statement. I did that but the simulation results remain the same. Puzzling.
assign End = signal_end;
assign over = signal_over;
collatz_comb comb_Part (driver, out, signal_end, signal_over);
Here is the testbench file:
module collatz_sequential_tb(
    reg [7:0] X;
    reg Clock;
    reg Start;
    wire [7:0] C;
    wire End;
    wire over;
    collatz_sequential DUT(
    .X(X),
    .Clock(Clock),
    .Start(Start),
    .C(C),
    .End(End),
    .over(over));
    initial begin
    Clock = 0;
    X = 3'd5; Start = 1;
   forever begin
   #20 Clock = ~Clock;
   end
    X = 3'd 24; Start = 1;
    end
endmodule
Just 2 test cases; I'm not sure if I've written the test bench file correctly though, but the clock seems to work. Here is a screenshot of my behavioral simulation:
Hi @florentw
I've did as you suggested, namely assigning outputs of comb_module to wires:
reg END, OVER;
always@(*)begin
collatz_comb comb_Part(driver, out, signal_end, signal_over);
Reg values are declared as well since I need to read them.
Here is my testbench:
    reg [7:0] X;
    reg Clock;
    reg Start;
    wire [7:0] C;
    wire End;
    wire over;
    .X(X),
    .Clock(Clock),
    .Start(Start),
    .C(C),
    .End(End),
    .over(over));
    initial begin
    Clock = 0;
   forever begin
   #20 Clock = ~Clock;
   end
    end
endmodule
 My testbench has two cases and nothing shows up on my end and over signals. Is my implementation of the FSM feasible?
Here is my behavioral simulation results:
Hi @limxx518,
You might need to investigate. Try to add internal signals to the waveform.
Did you try to do a test bench only for  collatz_comb?
Florent
Florent
Hi @florentw,
Thanks for your hints. Can you elaborate on what it means to add internal signals to the waveform?
Yes I did, and it works.
Hi @limxx518,
> In the object window, you can go deep into your design to see internal signal. You can right click on them and click add to waveform.
So it is works, how do you explain that the signal End is still unknown. It should be the output of this block
Florent
Well, it works, the simulation results are above.
I've tried adding the internal signals, but it seems that End and over themselves are the internal signals since they are declared as  wires in the testbench. Do you mean using such stuff as $display commands to display values of signal_end and signal_over?
Hi @limxx518,
No, I mean just finding the signals and add them to the waveform...
You might want to follow the simulation tutorial UG937. It will help.
Florent
Florent
EDIT: Ignore this post, I'll try debugging it on my own. Thanks for all your help so far!
Hi @florentw, thanks for the manual! It was of great help. I realized the error. It was the way in which I was declaring the inner connections when instantiating the submodules within this sequential module. Also, I realized that I need to provide structural verilog code for this problem, and I think I used behavioral code previously. So, I've made huge changes to my sequential module. Now, a different error comes up, and one in which Vivado doesn't tell me the cause. Firstly, here is my new code for the module:
    input [7:0] X,
    input Clock,
    input Start,
    output [7:0] C,
    output End,
    output over
    wire signal_end = 0, signal_over = 0;
    wire clock; //clock signal for counter
    assign clock = ~(signal_end | signal_over) & Clock;
    wire startbar = 0;
    DFF startn (.D(Start ^ startbar), .Q(startbar), .Clock(Clock), .ClearN(1'b1));
    assign Start = startbar;
    wire [7:0] Out;
    assign C = Out;
    wire [7:0] Y;
    wire [7:0] Data;
    mux_8bit input_select (.X(Y), .Y(X), .Y(startbar), .C(selected));
    parallel_8bit_reg register (.X(selected), .Clock(Clock), .ClearN(1'b1), .Data(Data));
    collatz_comb comb_Part (.X(Data), .Y(Y),.End(signal_End), .over(signal_over));
    binary_counter_8bit counter (.Load(startbar), .Count(1'b1), .Initial(8'b00000001), .Clock(clock), .ClearN(~(End | over)), .Output(C));
endmodule
Notice my assignments now have .input(arg) form. I was more confident that things would work this time, since I have a physical design of the circuit, but Vivado wouldn't let me run the behavioral simulation. It gives me this error:
[USF-XSim 62] 'compile' step failed with error(s). Please check the Tcl console output or 'C:/xup/digital/2014_2_artix7_labs/Collatz_machine/Collatz_machine.sim/sim_1/behav/xvlog.log' file for more information.
[Vivado 12-4473] Detected error while running simulation. Please correct the issue and retry this operation.
There aren't any other messages explaining why the error occurred. I can't find the log file as well despite going to the specified folder. I just managed to find the glbl.v file.
Any explanations why this doesn't work? Thanks and sorry for changing the problem.
HI @limxx518,
> Good to know. It is better if you find  the issue by yourself. I prefer be here to assist than solve for you.
There aren't any other messages explaining why the error occurred. I can't find the log file as well despite going to the specified folder. I just managed to find the glbl.v file. Any explanations why this doesn't work? Thanks and sorry for changing the problem.
> Try again to search for this file. It should be in your project directory under the <project.sim>/behav folder .
This file is generated because there is something wrong with you code (this is a verilog issue).
Alternatively you can look into the tcl console (or log console I can't remember which one). The error message should be displayed.
And if still not, you can try to run synthesis, it might show an issue in your code.
Hope that helps,
Florent
Florent
