Parse wdb file with script
Hello, I am struggling to find a resource that tells me how I can change wdb file into a format that a Python or Shell script could open and parse. Can I directly open this file with Python and make some sense of it? If it is easier to just poiint me to a resource where this is documented instead of an extended detailed answer, please point me to it.
回复: Parse wdb file with script
I'm afraid not. You can view the .wdb format with Tcl command. This is documented in UG900.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug900-vivado-logic-simulation.pdf
pg. 81 Opening a Previously Saved Simulation Run
Visitor flynnwt
This is a required function.  Xilinx needs to publish the format spec, or write a trivial tool to query or convert .wdb files.
