Planahead STRUCTURAL Fifo
my design uses various FIFO's. I'm trying to do a timing simulation using Planahead 14.6. (Windows x64)
Fifo generator documentation says I can generate 'structural' model by selecting it in the Core generator project options. In Planahead it is now 'LogiCore' and there aren't any options - by default (even listed in the wizard summary) it will only generate a 'Behavioural' model.
Will I have to call upon some tcl commands to generate the structural models for all my fifos??
Cheers.
Re: Planahead STRUCTURAL Fifo
I found a shortcut. Instead of setting the ip as top level, follow these steps:
  • Synthesize design as normal
  • Open synthesized design and traverse to an instance of the IP in the netlist hierarchy - note the cell/ block name in the properties window
  • enter the followig tcl command: write_vhdl -mode funcsim -cell path/to/block/or/cell/in/netlist C:\ip_name.vhd
  • Now add simulation source and select the generated file
Follow the below steps to generate structural model of FIFO core.
  • In the GUI, Set IP as Top, run synthesis.
  • After synthesis is complete, you can write out a back annotated simulation model for the IP by running the following commands from the TCL console accessible from the GUI.
    • write_verilog -mode funcsim <corename>.v (for Verilog)
    • write_vhdl -mode funcsim <corename>.vhd (for VHDL)
  • Add the model as a simulation only source for the flow to simulate the IP.
Deepika.
Deepika.
'Set as top' is greyed out for the IP instances in the hierarchy. the Fifo instance refers to the .xci file in brackets -
like this:
  - a_component - my_module - Behavioural (my_module.vhd)
       - BUS_FIFO - custom_fifo_name (custom_fifo_name.xci)
                custom_fifo_name - custom_fifo_name_a (cusom_fifo_name.vhd)
                custom_fifo_name (custom_fifo_name.ngc)
Can't set any of those as top.
I think you can write a wrapper with .vho and IP interface alone  in the top level entity, do not include any other modules, and set the wrapper as top level, synthesize and then use write_vhdl command.
Vanitha.
