fpgalab
Post Implementation timing Fails
Hello All,
I have a design which includes an HLS IP. The design meets all the user specified timing constraints , but it fails Post- Implementation Timing Simulation. The HLS IP is giving out wrong values.Also the Post -Implementation Functional Simulation gives expected results.
What could be the possible reason that a design will fail timing simulation while the design meets the timing constraints?
NB:The timing constraints just specifies the clock period. The same HLS IP when teseted alone gave expected results in Post implementation timing simulation. But when integrated to a larger design caused the above said issue.
fpgalab
Looks like the issue was with the Vivado Simulator.
When the code was run on the board it gave expected results.
Same issue was reported earlier :
https://forums.xilinx.com/t5/Simulation-and-Verification/Post-Implementation-timing-simulation-error/td-p/785099
https://forums.xilinx.com/t5/Simulation-and-Verification/Incorrect-Timing-Simulation/td-p/637029
Hope Xilinx will fix the above said issue.
watari
Hi @fpgalab
I guess because your design has some clock domains, there is different result between timing simulation and functional simulation.
Would you make sure clock domain crossing, CDC flip flop and the constraint for CDC ?
fpgalab
Theres no CDC.. Everything works with same clock.
fpgalab
It also showed warning during simulation :
"Timing violation in scope /NBTop_tb/uut/Pnum/gauss/U0/gaussian_fsub_32nbkb_U1/din0_buf1_reg[4]/TChk153_54807 at time 555521 ps $setuphold (posedge C,posedge D,(0:0:0),(0:0:0),notifier,in_clk_enable_p,in_clk_enable_p,C_dly,D_dly)"
fpgalab
