taimur123
Post Synthesis Functional Simulation Error Vivado
Hi All,
I am simulating my VHDL design on Vivado simulator. Simulation works fine until behavioral simulation, but when I try to run Post Synthesis Functional Simulation I get the following error.
ERROR: [VRFC 10-149] 'pkg_param' is not compiled in library xil_defaultlib [E:/Viterbi/encoder_decoder/encoder_decoder.srcs/sim_1/new/tb_decoder.vhd:8]
What I should do to fix the error?  "pkg_param" is a package I'm using to get some generic values as input.
hpoetzl
Voyager
Voyager
Hey @taimur123
It looks like Vivado is missing pkg_param in xil_defaultlib.
Is this a package you added to the design?
If so, can you show me the code?
Herbert
-------------- Yes, I do this for fun!
taimur123
But the package is already there.
taimur123
And yes I'm using that package in design, I also declared it in Testbench.
hpoetzl
Voyager
Voyager
Maybe this thread helps ...
Best,
Herbert
thakurr
Hi @taimur123
May be this AR helps you even if you are using new version of Vivado:
https://www.xilinx.com/support/answers/64097.html
Rohit
Rohit
